Hi guys, building a mitre saw station now(making 2 different tables at first and than fixating them together at middle and dropping also the mitre saw itself in the middle , can't post a picture but it's the same concept everyone is building.
I finished making it and made it so the mitresaw table itself is level with the 2 tables on each side, but when I tested it out it was more or less fine with very very straight timber, but as soon as the timber was a bit off it was lifting up from the mitre saw itself and you couldn't cut straight 90degrees every time, So I adjusted it and now the saw is 1.5mm higher than the both tables on each side and when you place a piece of timber on the saw it doesn't touches neither of the 2 tables and floats in air but it seems to work fine and now I can cut everything perfectly even if the timber is not perfectly straight.
but was just wondering what's the norm?
