Mister S
Hi all
I'm having some trouble setting up a mitre lock bit in my router table. Looking through previous post on the subject, it looks like the only way to set it up is by trial and error, for each given thickness of stock that you want to use it with.
While I was adjusting the settings, it dawned on me that both the horizontal and the vertical cuts have 2 variables:
1 - the height of the bit above the router table
2 - how far into the bit you move the stock
Since there are 2 variables for each, how do you know which one to adjust to creep up on a perfect fit?
Probably a "simple" answer, that's obvious when you see it
Steve
Steve
