acewoodturner
I was out on Saturday and Sunday with the Alaskan mill tackling a beech not too far from the worshop. It was windblown and had been down a couple of years. I was lucky that all the branches had already been cut off and moved from the area. It was only about 40' from the road on a level surface so that made life very easy. The diameter was 30" and the trunk length was 25'. I started off by cutting the top 8' off which fell half way over the wall and then the middle section. As the weight was taken off the log the bottom section then rose to an angle of about 45 degrees. You can never tell if its going to move slowly or suddenly sit bolt upright. Always a bit of a tricky one.
I ended up with 21 planks at 2" thick each with a max of 29" wide (this is the max I can do with this saw and 36" bar) Not bad considering I was on my own on Satiurday as my mate could only do Sunday, and we had to be clear before it got dark about 4pm. All the planks were 8 feet long, and I reckon the bigger ones weighed in at slightly more than 100kgs each. I have them stacked temporarily in the workshop as the kiln is running with a full load of 40mm oak.
