I bought the above to do a specific sanding job, removing plaster sealer prior to tiling (don't ask :x ).
I ran it for 20 minutes on Friday, and about 2 hours today, 45ish minutes stints with a 20 minute break inbetween. 60 grit at full speed on the coarse 6mm setting.
The sanding pad sheared off - and when I checked the motor housing and the allen bolt were very hot. The pad had melted off the retaining disk.
Have I run it too hard? or is this a dodgy one?
For the price and rating of this unit I was expecting to be able to use it all day long without a problem - do any of the others owners of this ROS in the group find theirs getting hot?
Sean
Sean
