Dissolve
Hi Guys,
I got my inverter hooked up today, and I'm really impressed with the setup, it's quiet, smooth and runs extremely well. I've run the drill at a slow speed and I can see a bit of runout/wobble which seems apparent around the whole chuck. It's visible enough to know something needs adjusting.
I am borrowing a drift key to knock the arbor out and take a look. I'm hoping re-seating the arbor will correct the wobble but if not, how do I identify what taper the arbor/chuck accepts? It's a Jacob's chuck and it looks pretty solid (not abused) but does someone know how I can identify what taper's they accept?
If re-seating the arbor does not work, how do I remove the chuck and re-seat that from the arbor? If that fails I will buy a new chuck and arbor to rule that out before digging deeper!
There is no play between the spindle/quill and I'd be surprised if it's been damaged as it looks well looked after.
Cheers!
Cheers!
