Martin's Dust Box
Bryan Bennett
3 Jan 2013
Newton Le Willows
Hi Martin I have made a box about 2" wide ( there not that much room underneath ) which fits just under the motor on the right and the body on the left.I have adapted Geoff's suction to work near the blade and I have a pipe going to the tube on the black plastic bracket that pivots to change blades.I have a piece of wood which slots just under the table with a hole in which supports the black plastic bracket and the pipe goes back to the pipes and then to the Henry.Martin what size is the box which you have made?.
Bryan
I'll check in the morning, Bryan, but at a rough guess I would say about 9" long x 2" wide x 1.5" deep.
I realise others might not want to do the same but I drilled a single hole in the front of the table to attach it. I could have done it without touching the table but this was the easy way.
Martin.
