Eric The Viking
- Joined
- 19 Jan 2010
- Messages
- 6,599
- Reaction score
- 76
I've got a tower scaffold up at the moment, for painting. It's being moved a lot as you might expect, requiring a lot of levelling. There are huge castors, and levelling screws in the bottoms of the columns, with acme-type square threads and three-pronged levelling washers.
I did try lubricating them before I started, cleaning with WD40 and then using a bit of engine oil, but it's next-to useless. The fullly-erected tower is pretty heavy, and they're still jamming up, beyond my ability to twist them and lift and grab the bottom (to stop that rotating), all at the same time.
Any recommendations as to a good practical lubricant for the job?
I've got lithium grease, copper grease, vaseline, Liberon machine wax, engine oil, hypoid gear oil, 3-in-one, "teflon" bike chain spray, and even the dreaded WD40. I can get something else if necessary. I don't care if they're too slippery (can easily jam them), but right now they're almost immovable under load.
Help very much appreciated on this, before I pull a muscle!
Cheers,
E.
Cheers,
E.
