Lost Jig design......
Argus
21 Oct 2002
Ceredigion Uplands
I’m a dyed-in-the-wool hand-made dovetail merchant and I’ve suddenly got a lot of drawers to do in one hit.
No problem there, except that I seem to remember reading an article of a jig or clamp arrangement that would help me considerably.
It appeared in one of the magazines some years ago (it may have been Good Woodworking or F&C – I cannot remember) featuring an article on making a clamp that held the sides of the drawers so that the vertical edges of the tails and pins could be pared accurately.
Normally I would clamp the sides down to the bench and do this vertically with a chisel.
It consisted of a pair of linked boards that clamped the work centrally with a horizontal lip to locate the chisel when paring. The work was held tight with an eccentric cam arrangement and the whole could be held upright in a vice. This gives the advantage of raising the work to a comfortable height.
I know it’s a long shot and I could probably come up with a design with a little experimentation, but does anyone remember the article and better still have a copy?
Hi Argus - I'm Pretty sure I remember something like it. It would have been in F&C. I'll take a look at a few front covers and see if it rings any bells.
Hi Argus,
I came across this on the Popular Woodworking website, while looking for something else and I remembered your question about a dovetail jig. It looks a bit like what you described anyway. HTH
Many thanks George. It was definitely one of the British comics, that I remember, but I haven't seen this one before so I'll have a look at it.
This one seems intent on guiding the saw rip cutting the tails and pins and uses a similar clamping idea.
The one I remember was a paring guide to establishing straight and square cheeks in the valley of the tail after you had done all the rest.
With diminishing strength in my wrists, keeping a chisel straight and square something that I don't find as easy as I used to.
best regards
