I'm looking for a drill press, for around 200 pounds and am happy to buy second hand. Previously i've just been using a black and decker adaptor which you insert a hand held drill into.
I have two main requirements for it.
Drum sanding attachment. I would do a fair bit of shaping work with this after finishing up on a bandsaw, the drums I use have a bearing part at the bottom to follow templates. This means applying some lateral force against the drill bit and I imagine this could make the motor work hard.
I also need something which I can get precise results with. I am planning to do some work with instruments which would need for example 10 holes in a line perfectly drilled without any noticable drift. Perhaps lazer guides would be handy here?
I've seen a few items on ebay, one is a Rexon 5 speed 340w lazer guided bench top item. Theres also a Meddings drill which looks like a very sturdy bench top model. I'm also happy to buy new.
Any advice would be great.
