nicguthrie
Hey folks, I'm looking for general opinion here.
I've been toying with the idea of a small Planer/Thicknesser for a long while. I've come to terms with finding other ways than a full P/T for simply jointing/planing board sides. so I started thinking about a small Thicknesser, but thinking about what I'd actually use it for, and the size of most of my projects, I've come to the conclusion that a drum sander would probably be a better bet. Almost everything I do is pretty small, and cutting rough to within a mm or so even from fairly odd shaped stock is pretty easy with a quickly knocked up jig, since I have the excellent BS350 bandsaw.
The trouble is that they (small drum sanders) seem fairly uncommon. It looks from my searches, that the choices are largely down to what's in the Axminister range, that starts at £680 for the Jet 10-20.
I do like the idea, especially of being able to make precise panels and inlay strips for jewelry boxes and such, but that's a hefty outlay, and a fairly large machine for the sort of thing I have in mind.
My real question is two-fold.
1) Those that have a proper drum sander - is it worth it in your opinion? As against say knocking up a jig frame and using a broad, flat router bit for thinning down stock for example.
2) Is there any other options that are more hobby sized (and budget) without going second hand? (My wife has real hospital grade OCD, so I can't do second hand)
One last option may be to knock up a home made one, but does anyone know how easy/reliable this is, or have any good guides & plans? If I was going that route, I'd hesitate if it was a lot of man-hours to do, as I don't have much time in the workshop as it is, and spending the next year of workshop time, making a home-made sander, I'd be better served just cutting out some other expense for the year, and swallowing the cost of a light trade machine even if it's way more than I need supposing it's small enough to fit in my little workshop.
Thanks.
Nic.
Thanks.
Nic.
