LN with a clifton blade?
shim20
30 Mar 2008
hadleigh,suffolk
hi peeps just got my LN no5 8) , but i would like an o1 blade in it, dose anyone know where the clifton ones fit?
many thansk
Not sure about Clifton Irons, but I have it on good authority that the LN O1 irons are currently out of stock :cry: , but they're in the process of making some, should be available in about 2 weeks :)
Aled
Yes, Clifton irons fit Lie=Nielsen planes
Here with Clifton iron and cap-iron
Here with Clifton iron and Lie-Nielsen cap-iron (and Clifton lever-cap, just for fun).
I found using the Clifton cap-iron I needed to move the depth adjusting wheel to a "higher" position (i.e. the Clifton cap-iron must be slightly longer from edge to yoke hole). Of course that won't happen if you only change the cutting iron.
Note that's a 55° frog in the Lie-Nielsen.
HTH.
Cheers, Vann.
    141 KB
    195.6 KB
thanks chaps, would you say its an improvement over A2? ive just seen the price of a clifton blade for a no5 :shock:, i have to say im really impressed with the LN 5 first LN ive had and what a plane they are
Whilst I might choose the O1 over the A2 at point of ordering, I sure wouldn't spend that much money changing (I hesitate to say upgrading) one to the other after it arrived.
BugBear
yes is alot of dosh, and tbh the LN A2 blade seems much better than my veritas block plane, which i find a pig to sharpen, ill see how i go
:oops: :oops: I haven't used either sufficiently to be able to judge :oops: :oops:
Yes both Clifton and Lie-Nielsen irons aren't cheap. Unless you can afford to keep both, it might be worth on-selling the LN iron to help finance the Clifton.
I think the Lie-Nielsens are very good looking planes, but I prefer Cliftons 'cause a) they're not made in the USA (Chinese products aren't the only ones I prefer to avoid (hammer) ) and b) that fantastic forged O1 iron.
And as a parting thought: I wonder how O1 & A2 steels compare at York and middle pitch, where the planing forces are applied at 5 and 10 degree higher angles?
Cheers, Vann.
