NickN
So, I am at the stage of insulating and lining the inside of my new woodworking shed and wondered if I could get some opinion particularly on thickness of wall lining to use.
I plan to place breathable 'paper' membrane flat across all the studwork (shiplap clad on outside), then attach 2 x 2 battens horizontally at 600mm centres with noggins every 1200mm, insert rockwool flexi slab, place vapour barrier membrane on the battens and finally use OSB 3 as a wall and ceiling lining.
Any ideas on a) if 9mm OSB3 is thick enough or too bendy for this, b) if OSB3 is actually needed vs OSB2, and c) any other options which won't break the bank, as I need about 20 8x4 sheets.
Thanks.
Thanks.
