raffreyturner
New member
HI,
I'm new to this - never owned a lathe before. I have a Charnwood 813 which is has problems with the speed change device. After rough turning a bowl at low speed, I found it difficult to raise the speed for finer turning. The belt drive appears to go very loose once you turn up the spindle speed. So even though the speed increases ( a bit), a very light touch of the bowl gouge is enough to bring it to a halt. Would appreciate any advice on what ought to happen to keep the belt under tension as the spindle pulley expands. It's a new belt by the way.
thanks
thanks
