C Sideways 2018
For anyone in the same position as myself, deciding whether to buy a used Kity 613 bandsaw and then setting about a clean and tune up, I hope the attached photographs and notes may be of use.
Thanks to everyone else on the web (especially the French forums) who has shared similar and often better information over the years.
My machine is an original model 613, made in 1993 by Kity SA in France. It was bought via ebay and looks to be lightly used. The alloy table is in decent condition for it's age, as are the tyres and blade guide assembly.
I decided to strip the machine down to check on the extent of some relatively minor rust, to deal with what appeared to be motor noise and to learn how to tune it.
As a general point, I find it useful to keep a small selection of stainless machine screws, nuts and washers in the common M6,8,10 sizes. As the saw will live in a garage workshop and suffer damp through winter, I replaced various fasteners with stainless if I had them on hand to avoid corrosion.
Starting with the blade guide. Clamp knob at the back, side nut has a pinion that moves the guide up and down by the rack cut into the back side.
The upper blade guide assembly just pulls out when the clamping screw is slackened.
The side guides are held in place with M6 nuts.
The side guides use plain bushes of some sort, not ball bearings. They turned freely so I didn't have to dismantle them (it's not obvious how you would, but a jig to pull them apart would be my guess when the time comes).
I am debating whether to lube these bushes - thinking about an aerosol like bike chain lube
The thrust bearing is a standard size sealed unit 6200 2RS. I ordered replacements by SKF, *** and NSK. I like the SKF best for this application. The old bearing is worn but serviceable so stays for now. A bearing puller will be useful when it is time to replace it.
The cast alloy table was unbolted and cleaned with some light oil and a "non stick" grade of kitchen scouring pad.
I replaced the existing M6x20mm hex countersunk machine screws with torx socket stainless. Stainless are not so strong as the originals but I think they will be strong enough. Torx sockets (I think even in stainless) are less prone to strip than the 4mm hex sockets of the originals.
The table tilts on a trunnion of pressed steel and cast alloy. I used a more aggressive scotchbrite pad to remove rust from the machined edges of the two steel brackets.
Note there are differently sized washers between the curved steel brackets and alloy casting. Take a note of the order of the parts when disassembling to make sure they go back in the right order.
End of part 1
Edit 2022: the embedding of the images in these posts were scrambled during a change in the forum software. All the photos are still included as attachments at the end of each post but I haven't yet edited the posts after this back into order. Hopefully the photos and text will still help in the meantime.
End of part 1
