Hi all, thought I would ask here as googleing brings up loads of confusing info!
I need to cut a L shape kitchen worktop, so will need to use a router jig to get it cut to size.
So you all know the drill(no pun intended)!
I have a 1\4" router, 1200 watt, don't have a cutting jig, or a guide bush,but suspect the holes are for 60mm bush.
So can it be done and any suggestions on the jig.
Will be used for two worktop installs, so don't need trade quality, but something that will least at least two cuts.
Also what is the usual rate for a worktop install out of curiosity...
Thansk
Thansk
