Shultzy
I've just finished the design for our new kitchen. All the carcass and door/drawer panels are in oak faced mdf (18mm for carcasses). Having never made carcasses before I though I'd ask a few questions.
Base Units
Should the sides be on top of the bottom panel or at the side?
Do I need a top on the cabinet or will 4-6" wide strips at the front and back suffice?
Back panel thickness 6, 9, or 18mm?
Is a false panel between door and drawer to hide gap necessary? Will 4-6" wide strips suffice
Pocket hole or just carcass screws?
How to join adjacent cabinets?
Do I screw the base units at the top and bottom to the wall?
Wall Units
Hanging brackets or French cleats. Can I use 19mm mdf for cleats or is it too thin?
Doors/drawers are 22mm Oak (Euro or US, not sure) in Shaker style.
Should the corner tenons be deeper than the 10mm groove for the door/drawer panels? I'm assuming when the stiles, rails and panel are glued together they will be strong enough.
Thickness of panel in door 9 or 6mm
How much allowance for lights under wall cabinets?
Oak, what type of finish inside and doors?
I know I can make the doors, but I'm not sure whether to make the carcase units or buy?
Base Units
Wall Units
