• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
For Sale JET JSG-31A BELT/DISC SANDER
Mooeee
28 Aug 2006
Hertfordshire
Here is a JET Belt/Disc sander only been used about 10 times and that was only very light work. It was purchased a few years ago but has been in storage in my container, now down sizing and have no use or space for this
superb machine.
It does not have wheels, so will require a machine base for it unless it is positioned in a fixed place, both tables are with it although only one is attached, bigger table has been removed for storage.
240 Volt
Belt size : 150mm X 1220mm
Belt Table: 190mm X 330mm
Belt Table tilt -45 degrees to 0 degrees
Belt Speed: 12m/sec
Sanding disc diameter: 300mm
Disc Table: 230mm X 420mm
Disc Table tilt: -45 degrees to +15 Degrees
Disc Speed 2400rpm
Dust Port diameter: 100mm
Suction at 20 m/sec 560m3/h
Output Power: 1,1 KW (1.5HP) S1
50 Hz
Reference Current: 7A
Overall size: 830mm X 700mm X 1400mm
Weight: 110kg
Instruction manual/user guide is with it.
Cash on Collection will be from:
Stevenage area approx one and a half miles off Junction 6 of the A1M.
It really is in as new condition due to very little use and having been stored with a cover over it.
£1275 I appreciate it's a big outlay but it' like Brand New, If you would like to view it please message me.
NSS are selling these Belt/disc sanders £1875
IMG20230323100709.jpg IMG20230323100731.jpg IMG20230424151659.jpg IMG20230424151542.jpg IMG20230424151539.jpg IMG20230424151458.jpgIMG20230424151429.jpgIMG20230424151314.jpgIMG20230424151310.jpgIMG20230424151435.jpg
