RogerS":3gszox5f said:
I went to IPLOOKUP.com and this said the IP address was invalid.
That's a problem with the iplookup.com site, it seems.
The same error is returned if I put an IP address of "46.37.178" in, or "a.b.c.d", which actually are invalid... it seems to be their general "I can't interpret this input as an IP address" error.
For an IP address (at least an IPv4 address, which is what most of the Internet uses) to be 'valid', it just has to be four numbers between 0 and 255, delimited by dots; there are some
reserved ranges (like anything starting with a 10, which is intended for local networks), but this IP doesn't fall into any of them. So I don't know why they'd reject it as invalid; it's a perfectly valid address.
I did look to see if there was a website at the address of the sender. The From address is
[email protected] (not zzzz!) but there is no website of
http://www.zzzzzzzz.co.uk
It's suspicious, but still not really conclusive; there do exist businesses who for some reason think that getting a website is beyond them, but like to have a domain name of their own to use for email. In the same way that there are businesses who have a domain name for their website but still use a hotmail address for their email!
(As it goes, the 'www' part isn't mandatory, and I've certainly seen websites before where "http://www.blah.com" doesn't work and "http://blah.com" does, so you could try that as well.)
If it's a UK domain, you could try going to
Nominet and using the whois tool in the top right to get some information about the domain - where it's situated, what the nameservers for that domain are, and sometimes who owns and administers it. If it's a US domain (.com, .net etc.), an equivalent tool is
here. You still won't necessarily find anything conclusive, but the more information the better, right?
