intumescent strips jig
If it's on the door then I just use longer rods and a second fence. Then use the right size cutter which these days is 15mm wide.
or, buy a dedicated cutter for your router. Save you lots of time setting up and pretty much failsafe.
The dedicated cutters aren't quite right (practically), although they obviously work a dream for fire seal, but for fire and smoke they aren't quite deep enough.
For what its worth we do all ours on the spindle moulder
Oryxdesign":3hlzhzni said:
http://www.wealdentool.com/acatalog/Online_Catalogue_Intumescent_Groover_105.html
That is what I was referring to. If you buy the correct one to match the seal you are using, whether it be fire or fire and smoke they work a treat.
quck edit, Ironmongery direct list their cutters on the same page as the corresponding seals. HTH, neiol
1 Fence works, clamp a thick piece of timber down one side of the edge to give the router extra support.
