Dave R":vok6obgv said:
I discovered that the opening for the guide is not centered perfectly on the bit on either of the two routers that accept them.
Dave
Both deWalt and Festool sell centring mandrels for use with their routers. These allow you to centre the guide bush before tightening the screws.
Johnjin
Whilst it is standard practice to cut then back cut in metalworking in woodworking many of the multi-station PTP machines around such as the Morbidellis and Biesses cut by default in the forward direction on the left end of the machine and the backward direction on the right end by simple mirror imaging of the CAM toolpath. This is to allow quick and dirty mirror-imaging of carcass end panels - so you don't get a choice without some nifty programming. For materials such as MDF and MFC this seems to produce a reasonable edge, especially with spiral carbides, etc - it all depends on what you're end finish/machining cost criteria are, I suppose. I tend to do a lot of bull nose (undercut work) so I have tended to hog out on a segmantal TC-RT cutter then finish with the bullnose in a single pass (on MDF). On tough plastics like HDPE, however I'd cut to within 0.3 mm or so of the line then make a second pass, preferably climb milling, to get a good quality machined edge.
I still do a fair bit on the pin router so having pairs of guide pins with 1.0mm difference in size can be a godsend. As you say back milling a thin edge won't tend to cause grabbing.
Don't fancy back milling with a hand held router, though, just in case you get a snatch.
Scrit
