Indexing on a Supernova
Bodrighy
6 Jan 2007
Bromham, Wiltshire
I was thinking of having a go using the indexing on the backplate of my supernova chuck. Can anyone advise me how to fix the chuck via the holes. The only solution I can think of is to fix a bolt of some sort to the motor casing to slot into the holes. Is there a proper way?
Pete me
A strip of metal or hard wood fixed to the bed one end and a pin/small diameter screw in the other to locate in the chuck holes.
Like this
I made this as an indexer for my lathe. Only works if you have double ended lathe, but the advantage is that the larger the ring the more accurate it is.
Paul
