Mdotflorida
My workshop is a standard block built double garage with concrete slab. I have well insulated walls and floor but open ceiling up to a felted and tiled roof.
The humidity always seems to be upwards of 85% with occasional days where it is nearly maxed out. I have lots of cast iron and this sometimes picks up a light surface coating of rust if I have not been in the shop for a while. Apart from this I have noticed the timber moisture levels rise. I recently had an order of Oak delivered. It was approx 6-8% (unadjusted) when it arrived. It's been sat in the shop for about 3 weeks and is now at approx 14% (unadjusted).
I have come to the conclusion that a dehumidifier may help. My question is do I need anything special. The only 2 features I am looking for are a continuous drain facility and an adjustable humidistat so that I can leave it running 24x7 at a set level. Should I look for any other features ? I have read that colder areas such as workshops should have a machine with 'Hot gas defrost !!!'
As with everything it is possible to spend a varying amount of cash on this. Has anyone got any recommendations ?
Many thanks
Jeff
Many thanks
Jeff
