'Hula' Engine.
Peri
11 Jun 2012
Shropshire
This is my take on the compressed air engine design by Philip Duclos, published in the book 'Steam & Stirling Engines You Can Build Vol2 (1994).
The original plans are in Imperial - to me that's OK for woodwork, but for precision my mind works in metric :)
First, I built the model in Inventor, tweaking the measurements to give 'nice' decimal numbers, and replacing screws and bolts with the nearest metric equivalent.
Did a simulated run to see if it looked like it would actually work and not bottom out somewhere.
Then make drawings for each part.
Everything was made from scrap bar or square stock.
I still have to dismantle it to give it all a good polish, but it's practically finished, all that's left to do is tap the air inlet valve to M5 and attach a permanent air line fixing.
It turns fairly freely by hand - tbh I was very surprised !
And finally, just because I had the computer model, a nice render :)
Thanks Nigel.
Cylinder has a 13mm bore, stroke is 21.2mm
I realised you can't really tell the scale of it. The base is 4" across and the cylinder socket screws are M2.5 (3-48 UNC). It stands about 7" high.
