I am very much a tyro.
Been making halving joints in 70mm x 35 mm framing timber. That'd be what? equivalent to your 3" x 1.5" ?
For making shelving.
Have to make 40 for each set of shelves.
So I line up the wood side by side and mark it.
Then use my power saw to cut many cuts through the waste wood down to 15mm.
That runs through the lot at once. One set of four uprights followed by one set of eight side pieces.
Then I chisel the waste out.
Then I am using my router to get down to 17mm.
The router jig is like two pieces of this timber side by side with the workpiece goes between them like meat in a sandwich. Can slide in and can slide out. I clamp it when it's at the right position.
On top of that 15mm timber makes a square to constrain the router so's it can slide across the width: 70mm and the length of the join: 70mm.
The router then very nearly falls off the timber at the far side when moved completely over to the other side.
Not very satisfactory. I'm just lucky it fits in this instance. But it's obvious I'd need some other kind of setup if I wanted to make bigger joints - but I can't think how to design a better setup.
So this is all what I've dreamt up in my state of ignorance while having to do this.
Can I ask for some education on what's the better way to do a job like this?
regards,
ab
regards,
ab
