oddsocks
I need to do some veneering in the near future of large flat and uniformly curved (in one plane) boards.
I've been doing some research into the cost of bagpress ( £255) and airpress (£485) kits, plus looking on ebay and other sites (such as Cole-Parmer) for vacuum pumps. I'm confused as to what 'vacuum' is actually needed to be successful (seeing some threads have used clothes bags and vacuum cleaners) and how to compare the different ways of reporting a vacuum ("of Hg I understand, in that 30" = full vacuum)
Can anyone help....
some vacuum pumps specs from various sites earlier today
EDITED with info from responses elsewhere in this thread and from this link http://www.unitsconverter.net/
A - 25 micros - this is a very very light vacuum, also referred to as mtorr.
B - 3m3 per hour - the flow rate, higher numbers help bigger bags and shaped formers (get the vacuum in before the glue sets,
C - 23" Hg - 30" is a full vacuum. 23"= 11.3 PSI, 584000mtorr, 778mbar (I have seen motors that say 780mbar)
D - 10 psi - approx 20.3" Hg
E - 600 kg /m2
Anyone care to put this in order of highest vac to lowest and then identify what the threshold is for successful veneering??
Also many sites that sell new or used vacuum pumps imply they are for lab use - is this a relevant factor?
I have searched the forum for 'vacuum pump' and read most of the hits but not found the answer.
Dave
EDITED again.... after the original title was answered the dialogue continued around the types of compressors, pumps etc and I managed to get a vacuum pump from freecycle
Can anyone help....
E - 600 kg /m2
Dave
