Home made Jigs Thread?
seaco
17 Feb 2005
Somerset
Thought it might be a good idea for us to add pics of our homemade jigs so we can all see what each other have come up with?
I for one love to find new jigs to make life easier, so go on add your jigs here...
Explanations on more unusual ones might help!... :wink:
One to get it started, this I use to cut small strips etc. from a board as I have little room to the left of my saw.
You first measure from the blade to the round section on the jig to get the initial measurement then make your first cut then all you do is move the saw guide pushing the board over untill it just touches the jig again, simple and works well...
Not sure wether this counts as a jig :)
I don't have enough space for a table saw or even for a chop saw with a good table. I have only a good portable saw and have to improvise the rest.
A little modern variation of the miter box:
You can screw a stopper to the planks under the box to cut to proper lengths. And 45 degrees as well, if needed. Admittably a bit slow, but gives you the same results as a proper chop saw.
The box stores away easily and it can either be used as it is on the bench (just ensuring 90 deg cuts) or screwed on to a pair of planks with an added stopper.
Pekka
Here's one for enlarging holes, I can't claim any credit though all credits are due to Weekly tips from the editors of Woodsmith, ShopNotes, and Workbench.
Use a Simple Guide to Enlarge a Lockset Hole or any hole
When I need to enlarge a hole in a door for a new lockset (say, from 21/8″ to 23/8″), I use a shop-made guide and a standard hole saw.
The guide is a scrap piece of ½″ plywood with a hole that’s sized to accommodate the lockset. Use the paper template that comes with the lockset to locate the hole in the guide (Guide Layout Detail).
Drawing and Guide Layout Detail
After cutting the hole with a hole saw, align the guide on the door. (I attach scrap blocks to the guide to register it flush with the edge.) Now clamp the guide in place, and use the same hole saw to enlarge the opening in the door. The guide keeps the hole saw straight, ensuring an accurate cut.
Good woodworking,
Wyatt Myers
Online Editor, Workbench
Heres a couple of mine, although the first one I cant take credit for as I found it on the internet. Very useful though. It is a dado jig for the router and once made the shelf can be fitted between the rails to the correct width and then placed on the side panel. Butt the router up to the left side nd cut up the panel and then butt up to the left side and rout down, the shelf will be a perfect fit.
Make each side panel with extra long pieces of 1/4" ply and then trim off the excess witrh the router and bit to be used, it is then ready to use. :wink:
As I have been making a lot of gates recently I made this little jig to cut the rebates for the T&G V panels. Fitted onto the base of the router and with a half inch bit in it will cut the rebates while the block below it runs on the uncut timber below following the open panel of the frames and stiles. It is a boon when cutting rebates in arched top gates.
The rounded end of the wooden block should just clear the cutting bit below the base plate allowing the cutter to still clear chips. :wink:
Just remebered this one I made for cuting small circles wih the router. Below the base plate attached to the threaded piece is a small pin which the jig rotates on.
Here's one I made for the slot on the table saw, jig fixes to the protractor with a couple of short bolts. Its for cutting a slot in a picture frame for reinforcing a mitred joint. I used to cut the slot by hand a use a piece of veneer but that's a genuine pita 'cos the veneer is never the same thickness as the saw kerf. Now I just run the corners through the jig and insert one or two thick pieces of a contrasting timber which is much easier and makes for a better and stronger joint - Rob
A really simple one for when I'm cutting thin strips I find that if the blade is close to the guide there can be a problem pushing the wood past the blade so this solves this and stops any chance of binding...
Let's not forget Niki's excellent contrib's. I hope he won't mind me posting the links here?
Different way of cutting 45* frame
Cross-cut sled, different way to make it.
Shop vac modifications
Drill Stand modification
Drill press table improvement
Screw cramps
Sanding blocks
Hold down clamps
For amateurs only
Cheap "Grip-it" clamp repair and improvement
Saw blade and router bit height guage
Cutting dado with hand router
Hand router bit height setting aid
Caliper (micrometer) modification
Another Shop-vac
Clean paint tray
Wild router table
Foam brushes
Doweling with router table
Drilling shelf support holes
Magnifying glasses
Panel glue-up aids
Jointing with router
Doweling jig part 1
Doweling jig part 2
Feather roller for table saw
Push blocks
Feather roller - version II, prototype.
Straight edge on table saw
Feather roller, final version
TS fence memory
Dust free sanding
Amateur's working methods
Hold down roller for TS
Panel glue-up, overcoming cupping boards problem
Cutting strips on TS
CS cutting table
Saw blade cleaning with STP
ROS DC improvement
Router table fence distance and stops setting
CS (or router) Offset plate
CS with Zero clearance insert, why it's chipping?
T square
Measuring tape, not only for measuring
Measuring tape - version II
Construction Square - checking & adjusting to 90*
Blade cleaner
Triangles
Jointing with hand router II
Checking Diagonals
Checking Diagonals, version II
Checking Diagonals, version III
Checking diagonal, Version IV
Logs or round wood cutting jig
Router Lift for amateurs
Glue line on router table
Triangles
WOW :shock: That took longer than I thought ;)
Well done Niki!
Thank you so much
Actually, I wanted to post some jig but I did not know with what to start...
WiZeR, you solved the problem nicely, Thank you.
A few (well, many) pictures were missing just because I changed the file name in Photobucket, (thank you Shultzy for notifying me), but I re-loaded all of them (except a few unimportant).
Thanks again
niki
