I bought some of the trend version of the non slip `bench cookies` type things a while ago. I found them quite good but found the rubbery bit was not stuck on very well and moved around a bit during use, also its not that thick.
I was repairing a wooden steering wheel which needed clamping without leaving a mark. After thinking about it for a while and rooting about in the shed, I found an old mouse mat, the thick neoprene type with cloth on one side.
So I cut up some scrap wood into little squares and glued pieces of the mouse mat cloth side down onto the blocks with super glue.
This worked very well as clamping pads on the round edge of the steering wheel.
I noticed the non slip attributes of the mouse mat and so tried sticking some onto the other side of the block to make a non slip bench cookie.
In short, they work better than the ones I bought and cost exactly nothing, also can be made any size or shape. I am sure almost everyone has old mouse mats hanging about (or even a wetsuit ) , so now you can use them for something useful.
Ollie
Ollie
