Scoffy":qz19t7je said:Water based floor varnish! I use this quite a lot as it does not chage the colour of the wood.
Alex_E":vw9wmwlq said:Sadolin always seems good to me! Never had an issue. or osmo as well they are also very good.
Not if you want it resistant to marking. If you use wax at all, use microcrystalline otherwise the door will show every handprint and fingerprint.ebs":3502wpz3 said:would it work if i used clear wax?
phil.p":27x4xpgw said:Not if you want it resistant to marking. If you use wax at all, use microcrystalline otherwise the door will show every handprint and fingerprint.ebs":27x4xpgw said:would it work if i used clear wax?
RobinBHM":1cwey1vb said:Polyvine clear wax varnish is pretty clear, axi sell it
