Help! What size pulley?
SammyQ
12 Apr 2005
A wee house on a hill
I'm at last - after long term illness- finishing the renovation of an elderly Wadkin AGS 10" saw. I have a 2.0kW three phase motor for it and I have just ordered an inverter to run it, when I stopped to think:
This motor runs at 1440 rpm; the saw arbour pulley is approx 3"; surface speed on the blade should be about 12000.....
Quick calculation: [10/12 x 3.142] x RPM = 12000, ergo RPM = 4583
To get 4583RPM arbour from 1440RPM at the motor, I need a x3 Pulley step-up......9"..............!!!!!! :shock: :shock: :shock:
Is this feasible or am I am a complete and utter dork, airhead, mentally deficient etc etc? Should I go out and seek a faster spinning motor? Can I carry on and fit a pulley that would make Swartznegger pause for thought when he saw it?
This with £70-odd invested in the inverter (in the post) and SWIMBO in full nag regalia seeking a completion date (yesterday) for three outstanding jobs....did I say that the illness was chronic depression?
Sam - panicking ever so slightly.
Sammie
My brain doesn't work properly any more either. Perhaps we should start a sub-forum...it's not just us, I can assure you.
What is the problem with a 9" pulley? I've not checked your maths, but assuming they are right, 9" does not seem outrageous to me. Or you could use a 6" and 2" to get the same ratio.
Unless we are both missing something.
Keep taking the tablets. I do.
Best wishes
S
Hi Sam wheres the pictures. :D Heres a link to a site that made all the speedy stuff easier for my little brain to understand.
http://www.vermontamerican.com/NR/rdonl ... MChart.PDF
If you had a 6" pulley on the motor and a 3" pulley on the arbour you would get a speed of 7,536 feet per minute
If you had a 9" pulley on the motor and 3" pulley on the arbour you would get a speed of 11,304 feet per minute.
According to this site you need a minimum speed of 10,000 fpm and a maximum of 18,000.
So with a 9" pulley you should be ok. Unless you were to change your motor to a faster one 2,800rpm.
When I did my Sagar saw bench I had a problem with the pulleys, if I remember correctly the pulley I had on the motor was too big and the static converter nearly popped a gasket with all the juice the motor was drawing on startup. When it did get upto speed the noise it was ear shattering. When I did the sums it was running the blade at 24,000 fpm :oops:
HTH
Mark
Steve, thank you for the support. I did a quick mock-up and realised that a 9" pulley fouls the motor mounting plate sheeesh.... "BEGINNER!". Mark, those run figures agree with what I read elsewhere; I think a plan may be to switch the arbour pulley to as small as I can get 2" maybe or 1.5" and then the drive pulley on the motor will shrink to fit. Photos? Yup, I know, I keeep procrastinating, but I DO have them and they're coming!
Have you bought a digital inverter? If so you can run the motor at a higher frequency to up the rpm.
This is common practice on woodturning lathes as you get the torque of the 4 pole motor with the speed of a 2 pole. The frequency that you can run you motor at will depend on the quality of the motor, mainly the bearings but you should be able to safely hit 2000rpm + meaning you won't have to fit such a big pulley.
There's quite a bit of information on the web about this practice so I recommend that you have a read.
Bear in mind that the smaller the pulley, the more energy it takes to drive the belt. I found this out the hard way when I down-speeded a bandsaw to cut metal - I used 3" and 6" pullies for the step-down, and ended up having to fit a more powerful motor to compensate.
Thanks Andy, wasn't aware of that; got any tips please on particularly good sites you've used in this repect?
Thanks Woodmangler, that is a pitfall guaranteed to exaccerbate frustration and best avoided!
Sam, now stopped hyperventilating.
There's loads of information here: http://www.practicalmachinist.com/vb/transformers-phase-converters-vfd/
Also this company sells a range of inverter and motors packages using 4 pole 1400rpm motors and rating them up to 100hz allowing them to run at 2800rpm, these are just standard off the shelf 3 phase motors.
The bearings found in 4 pole motors will be the same as found in a 2 pole motor running at 2800rpm, and bearings of that size will be good to way above that at approx 15,000rpm+. I'm running the 1400 rpm motor in my lathe upto 85hz, I'm not sure what speed this is, 2500rpm?.. without any problems, I used 85hz at my max as that gives me the approximate max rpm that the lathe would of originally run at.
Andy, you're a star! That forum will keep me off the streets for days.....What company were you linking to please? It didn't appear on the thread? Sam
