Thanks Chippygeoff, I will look tomorrow. If they're not slots in the plate, they soon will be, as they have done an engineering change and I just have to upgrade. It's a pity Hegner UK didn't know anything about it.
I also get a knocking/rattle with the saw at higher speeds, but I think I have found it is the motor alignment. The drive plate had a difference between the back and the front of around 1mm from the plane that the drive link swings in, and the knocking was significant at 1100 rpm. I got it down to around 0.5mm and it is higher than 1200 before it starts. I will have another go later to true it up, but it's a tedious exercise so i need to be awake to do it. lol
