• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Sold Heavy Duty Nylon Castors on Bearings - (ALL SOLD)
Moonsafari69
30 Jun 2016
Moira, Swadlincote
I have another batch of these very heavy duty solid Nylon Castors. I will add some photos including a sketch with the dimensions of the base plate etc. The metal frame of the castor is quite substantial at 3mm thick so these have been manufactured to take some serious weight. They are fitted with a bearing race which makes the rotation is very smooth. I have used these for making loads of items more mobile in the workshop. A good use i've found is to bolt them to the bottom of the supermarket delivery crates which makes a great mobile storage system.
Dimensions:
Baseplate - 92mm long x 65mm wide x 3mm thick
Nylon Wheel - 50mm diameter x 40mm wide
Height from bottom of castor to top of baseplate - 75mm
Price:
Castors are £2.50 each
Delivery - (via EVRI)
Delivery Cost Example 1) Up to 8 castors @ £6.85 which would be just below the Evri 5kg limit.
Delivery Cost Example 2) Up to 16 castors @ £7.26 which would be just below the Evri 10kg limit.
I can't post single deliveries heavier than 10kg but multiple deliveries are of course possible if required.
If anyone wants to collect in person my post-code is DE12 (North Leicestershire / South Derbyshire border).
Some more photos:
Thanks, Dave.
