mindthatwhatouch
Well I finally took the plunge and ended up with an Xcalibur Table saw. My first proper table saw so in need of a bit of help.
After a much needed clean I have discovered a couple of things that I need a bit of advice on.
First thing is the rise and fall mechanism makes a bit of a grinding noise. Though the mechanism is much easier to move now it's clean. Tracked this down to the rod rubbing against the riving knife bracket as pictured below.
Presuming there should be a gap here when I bend the bracket away from the rod how much of a gap?
Or should I add a spacer between the arbour and bracket or take a bit off the back of the bracket. It doesn't look like anything has been disturbed since manufacture so maybe not the spacer and it doesn't look like anything else has shifted so assuming it got slightly bent/moved during dismantling/transportation.
Guessing some form of PTFE lubricant is ideal for the pivots, worm and screw etc.
The previous user has a few white plastic shims between the existing blade and the backing washer, is this normal and whats the idea of these?
Can anyone advise if this set up is suitable for a dado stack? not used one before so no idea on the mounting arrangement.
Many thanks in advance.
