Gold plating.
MIGNAL
6 Nov 2005
W.York's
No, not the real stuff. That cheap, blingy, nasty coating they put on metal objects to imitate gold.
Will an antiquing solution work on it? or anything to dull the blingy shine!
Hi - you might try patinating fluid on it- I had a rim lock on a dark sapele door and as you say the fake gold looked awful. I used some Liberon antiquing fluid - the blue stuff, and it kinda worked, it was very patchy even though I had ensured all the clear lacquer was removed 1st.
Will post a picture when I am back home
Ed
blow torch.
test on small area first. it's a zinc coating with a yellow pasivate so will blue and darken pretty quickly with a tickle of heat. :)
Thanks. Actually I now think the item may be brass that has been highly polished then laquered, so I guess that removing the finish and then using the fluid will result in an aged look, which is what I'm after.
