transatlantic
Boom!
Lets say you're wanting to create a natural edge bowl and you have a blank like below where you don't have quite enough material for a tenon. If it was dry, you could use a glue block. But in the case where it's green, what are your options?
I was looking at the PU glues, and they seem to work up to a moisture content of 25%. Could you perhaps leave it a week or two until just the outer most layer (3-4 mm deep?) is reading 25% or below and then use PU for a glue block?
