L2wis
In the past I've just pulled it out of the headstock, however its not budging this evening. What's the best method for removal?
Thats the way to do it :lol:Blister":is9c30zp said:If you lock the main shaft with a spanner
you should be able to undo the thread protector and that will pull out the mandrel
Yep it did the trick!!Dieseldog":1mdvcajl said:Thats the way to do it :lol:Blister":1mdvcajl said:If you lock the main shaft with a spanner
