nicguthrie
Hey, I apologise if this is a subject that's been done many times or answered in depth, but I'm yet to discover the intricacies of using the forum on my phone!
I've been making pens and key fobs for friends and family recently, and have been using some gorgeous spalted and burr pieces of wood, but I've hit problems a few times and thought I'd appeal for advice from those wiser than I.
The blank has shattered several times, just as I'm finishing up and it's getting thin over the brass tube insert that it's glued to. I suspect that part of the reason was that the way I'd glued the tube in, it had not been held all the way thru, but by a few points where the CA glue had made contact before drying, so I'm trying a thick, slower drying epoxy, painted right along the length of the blank hike before inserting the tube - see if I get a more uniform attachment that way.
I was advised to try soaking blanks that are pre-known to be fragile, in watered down PVA then letting them dry before turning, but I'm worried about that changing the way finishes look.
I'm just wondering what other tricks folks may know for stopping these disappointing broken blanks, especially since some of the more rare ones can be expensive! I'm planning to get some ancient Kauri as a personal present for a friend, and don't want to lose any of those blanks - they can be up to $75 for 10.
It's also rather disheartening to lose a project just as you're finishing the final curves on it, so any advice will be greatly received!
Thanks in advance
Nic.
Sent from my GT-N7000 using Tapatalk 4 Beta
Thanks in advance
Nic.
