Ok random I know, after fighting with for 15 years with BT to get any sort of broadband up here I've given up, the satellite solution I currently use is pants and was recently offered wifi from a local mast.
The installer came today but I need a 10ft pole to get the elevation I need, and the only place to fix it is the gable end which is a stone wall 2ft thick, he refused to install it saying that he couldn't guarantee that he would get a good fixing to the wall with thunderbolts or fisher fixings.
He has left me the brackets and told me that if I get them fitted securely he will come back and fit the wifi dish.
I would have liked to use threaded bar right through the wall but the inside is studded and I have no access bar a 2ft gap at the top in the loft due to the profile of the ceiling.
Given that the dish small that it is will be hanging off the end of a 10ft pole and I live on a windy mountain, can anybody suggest any way of fixing this securely, I don't want it becoming a lethal projectile....would I get away with using really long/heavy thunderbolts, I think fishers could blow the stone, had thought about chemical fixing, but its not really suited to stone unless you have a clean hole from what I can tell.
I'm not going near the workshop tonight, cause I've learnt from experience that anger and sharp tools aren't good bedfellows !! :evil:
Please help if you can, my heads fried, a lot depends on this
Karl
Karl
