mickthetree
Hey all
I scored one of the Jessem router plates (Phenolic resin) and tops in the rutlands sale and I've gotten round to mounting the router this evening.
I have a Macallister router that I bought off a forum member some years ao. Its a 2kw beast, very heavy and I'm happy to mount it perminantly in my table. It has a fine height adjuster built in and I've removed the spring and it does just what I want.
There are four holes that hold the current base to the router. These are fairly thin threaded screws.
There are also three larger holes for more hefty screws, however if I use these they get a bit close to the edge of thehole in the plate.
Hopefully this pic will explain more.
So should I use the larger screw holes that are closer to the hole in the plate? or the smaller screw holes that are more spaced, but use thinner screws?
