johnny.t.
Well first try with the maxi 8) Sadly the inserts for the chuck haven't turned up yet so I had to use the little faceplate that came with it.
I mounted a small dry unknown log that was given to me on the faceplate which turned out to be Ash.
I went for the middle pulleys of the five sets which give a speed range from 170 to 1740 rpm.To do this an allen screw has to be undone on the top cover(there is a nylon bolt head behind the top cover for it to rest against when opened so it dosen't bang{I like things like that,shows a bit of thought in the design}), the motor is loosend by a knob on the side,the motor lifted and belt moved over top and bottom. A bit of tension is then needed on the motor as the knob is done up. There is a safety switch on both the top cover and the bottom motor door so you can't get your fingers in there with it running.
So I started it up and the thing is so much quieter than the Axi lathe. I roughed out a little form, which was a real joy to do, the tool rests are strong and smooth and the 2hp spins the wood effortlessly compared with my old lathe which would slow against the tool effort.
Another really handy thing is that inches are marked out on the tailstock spindle so when drilling the middle of the form you know how far you have gone.
I hollowed it out which again was just so different compared to the struggle with the old lathe. Sadly a crack in the pith of the timber meant I had to enlarge the opening but rather than start again I decided I would make it a collar.
A bit of a scorching to make the Ash look more interesting
Then I mounted what Yandles sent me as a sycamore bowl blank(got some blanks as part of the deal) to make a collar. Formed the tennon to fit in the form and used this to reverse the form to finish the foot.
Decided to go for a Nick Arnull type collar so undercut around the tenon cut it off and made a socket to reverse it and shape and sand the top.
Another neat little feature is the faceplate has two allen screws that tighten behind the spindle thread so even if it came a bit loose it wouldn't go anywhere.
So I've made some shavings with it now
So far I'm very very impressed 8) The variable speed works a charm,its so quiet I even turned the stereo down :lol: ,its solid,stable and everything moves and locks in place perfectly. I'm happy so far 8)
A bit more work on the form was needed, I stained it yellow with spirit stains and coloured the collar with acrylic and finally sprayed both with gloss laquer and glued them together.
Oh and I cleaned up the workshop afterwards :lol:
JT
JT
