Ok, so got it earlier as well as a box of bits (another thread about what some of them are!) but seems to be a good deal, also in the box of bits there seems to be a pen mandrel and some blanks and some other odd looking things.
anyhow, all set up and turned 2 bits of scrap wood, the first needed to be knocked into the drive centre more as it come loose and got a bit too close to the centre so ended to remove.
the 2nd was a block of wood from a pallet, this turned out really well, i think it is pine but a bit of coving and cuts with the parting tool and used the larger tool to rough it down then the smaller one to tidy.
anyhow, back to the questions :
1 - the alignment of the headstock and the tailstock is slightly out. i have it pretty much spot on centre when looking down but looking up/down it is about 1-2mm out. I can't see how to resolve this, as it seems pretty much 'fixed' as is, so is there anything i missed when putting it together? it is the one with bars which apparently are not that 'accurate' compared to a cast bed, or is it something that isn't that critical for what i am doing?
2 - there is a NOVA chuck, seems to be all there but there isn't any way to tighten the jaws so they can't move. it looks like there are holes but nothing in them. should there be the small nuts that you use allen keys for in there and if so any idea what size so i can get some?
3 - on the headstock there is a twisty thing over the thread, what is this for? doesn't seem to hold anything but does seem to be used to 'push' out the drive centre good.
4 - is there anywhere on them to ID the age/year, the motor has a load of text on about specs/etc but no obvious date. be interested to know as it seems to be built like a bloody tank!
