LancsRick
There are countless things I still have to learn on woodworking, but the one area where I'm probably really ignorant as to the extent of my lack of knowledge is finishing. To address that, I thought I'd look to expand my selection of finishes a bit so I start learning a bit...
At the moment my selection comes from:
- if it's turned, it gets cellulose sanding sealer and then microcrystalline wax, buffed up on the lathe (from ornamental to moderate use)
- anything that's heavy use defaults to danish oil
- anything that needs to be waterproof gets varnished
So, from that highly limited starting point, what would you suggest I start exploring next?
Thanks in advance!
Thanks in advance!
