Evolution Rage 5 blade recommendations
EssexMurph
4 Jul 2019
Essex
Hi All,
First post on a forum ever so please be gentle. As the title suggests I have a rage 5S as my table saw (will consult on here when I get an upgrade)
I am after an upgrade to the blade as the standard is ok but I’m looking for a bit more. In short I want a combi blade for both rip/cross cuts and understand I need a few more teeth than the current 28 to get a better quality of cut. I’m not churning through thick lumps of hardwood either if that helps with the advice
The issue is I’m struggling to find anything with a 1” bore that has what I am after.
Any recommendations will be much appreciated.
EssexMurph
4 Jul 2019
Essex
Thanks for the quick responses.
Freud has a blade that I really liked the look of but didn’t seem to have the right size arbor.
I had looked at saxton blades but didn’t realise they provided the additional sizing rings. Thanks phil.p for the heads up. You win!!
