As you've probably guessed by the subject heading - I'm a noob!
I'm in the process of making a subwoofer out of 25mm mdf. Most of the carcass is ready, however the sides have not all joined up as evenly as I had hoped. This means I have some slight lips/overlaps.
I will be veneering the box so need to get it all evened up. I don't have a sander (could get one if needed), have 18grit sandpaper and a router with two straight bits and an ovolo.
My question is - can I use a combination of the router(?!) and sandpaper to get even joints, or will I need a sander? The overlaps/lips are a couple of mills at most.
