Nice work. From these photos, it looks as though you don't need much advice at all! :wink:
I'd always check and make sure everything goes together square, when making drawers - and that includes creating the openings as you're gluing the sideboard together.
It does looks as though you've used pine for the drawer sides...? That's a little disappointing, given that it's such a soft wood - usually, you'd want your sides to be as 'hard' as the fronts, if not more so. Just make sure you put plenty of beeswax on them.
Drawers can be tricky to fit at the best of times but, in the winter, you could be faced with more problems later on if you're fitting them in a workshop that's short of heat and insulation... In that kind of environment, the timber will probably take on a small amount of moisture. Once you then bring the piece in to a home with central-heating, there's a risk that some of the wood could shrink, leaving you with slightly larger gaps around each drawer... Some timbers (oak) are inherently more stable than others (pine). Some would say that's better than the opposite scenario in the summer, where humidity could cause the drawers to swell, stick and jam!
I do agree with your decision to go with a lighter species for the sides though, to contrast against the darker pins on the fronts. However, for future reference, you might want to look for some maple or sycamore (relatively inexpensive).
I hope that none of the above sounds critical.
What are you going to finish it with? Look forward to seeing it complete.
