I have some nice boards of kiln-dried elm which I bought last autumn and have been sitting indoors getting acclimatised ever since. They were a bit of an impulse buy on eBay but the price was good.
I've come around to thinking they would look nice in the kitchen, so I am considering making them into panel doors.
So, is this wise? - you don't see many elm kitchens. Is this because it is fairly scarce, not very trendy at the moment or is movement too much of a problem?
The wall cupboard doors will be glass fronted with a 80mm wide frame- should I put the glass in the narrowest rebate to give rigidity or will the glass crack if the wood moves? Alternatively should I use a standard panel cutter set with a 6mm groove and take up the spare 2mm with something flexible?
Others will have wood panels, but my wife favours thinner panels rather than raised ones. If I make 6mm panels will the doors have enough resistance to twist?
Finally, does anybody know a supplier with a good range of profile scribing sets - most have just the standard ogee which is a bit fussy for a kitchen - I'm thinking about cleaning them now and are looking for something with a gently sloping edge rather than a complex curve.
Any advice would be gratefully received
