Ebonising Beech
Baldhead
7 Jun 2012
In Limbo (Northumberland)
I remember years ago reading an article in a woodwork magazine about ebonising beech, does anyone know how it is done, and also would I be able to sand it after it's been ebonised?
Baldhead
It's probably not the textbook method but I once made a replacement chess piece for one that was lost and was looking round for an easy way to make it black. I used a decent quality black permanent marker (spirit based ink) and followed it up with black instant shoe cleaner - the sort that comes in a plastic tube with a sponge on the end. It worked brilliantly. Not so good on a larger scale piece though. I wouldn't have sanded it afterwards, but I didn't need to.
When I needed some small black drawer knobs I just got some black wood dye and applied several coats over a period of a few days sanding between. I had beech handles, so I tried them, it was very successful.
They are still quite black.
Mick
I did a sample where I dyed the wood black and added some dye to shellac and put that over the dyed wood. A nice shiny black and getting towards a "piano black"
You almost certainly can't sand after ebonising.
Old trick from my musical instrument repair days is what we stained the fingerboards with on cellos and violins, I used this method to re ebonize the beech infill on a Norris A5 once and it worked brilliantly. It's not actually a stain as such, more a chemical reaction. Just get some quality permanent black hair color and follow the instructions. It works a treat
richarnold":2lbcrpzp said:
Just get some quality permanent black hair color and follow the instructions. It works a treat.
It's amazing what can be done using "ordinary household products"!
When my Grandad retired, they moved into a modern(ish) flat and it had a set of open ended shelves which he didn't like at all. I won't get into the detail of how he closed in the ends and fitted it out to have sliding glass shelves - he was a very clever engineer and very good amateur woodworker!
BUT, I do remember commenting on the colour matching of the new wood and the old - and he replied "Gravy Browning"! :shock:
