Dust extraction - flex hose. Smooth vs normal
Also please note that the DC Sideways linked is a North American machine running on 60hertz. If it is available in the UK it will be 50hertz and you will need to factor an instant 20% loss of flow from their performance figures.
Colin the surface drag extends out from the walls more than you would think, affecting the flow overall. One of the reasons dust collector flow claims are up to double of what they actually can move. They take the reading in the centre of the duct where the flow is the highest. Take readings across the duct and the average brings it down. Even the addition of a bell mouth entry can improve the airflow in a duct by several percent just because it smooths out the airflow at the inlet of the duct. Without it the sharp entry has a turbulent zone around the edge that reduces the flow into the duct. Think of it like the wing of an airplane. The smooth flow over the wing generates the lift to allow the aircraft to fly. Cover the wing with frost and the drag from those ice particles are enough that the aircraft can't fly or even get airborne. It all adds up especially in a small system where there is little difference between good collection and failing.
Edited to make the last line clear.
There is also turbulence to take note of which will be more on a hose because of the shape. Bear in mind as you say flow claims will be measured in the middle to try and ignore turbulence problems. Same as performance claims on a car.
