StevieB
I needed a cheap drill press recently so at the weekend picked up one of the perform ones from Axminster. All was going well with putting it together until I came to the chuck. This fits a tapered spindle and is supposed to be tapped onto the spindle with a hammer and a block of wood. For the life of me though I cannot see how the chuck and spindle stay together. The spindle appears to be smooth, and the chuck has a smooth bore. There appears to be no spring clip or ridge or anything else to hold the two together.
Am I being paranoid, is this the way chucks usually fit to spindles, or should there be some mechanism to prevent gravity exerting its influence and separating the two :?
The chuck has stayed on the spindle while I tested the drill, but I havent used it in anger yet just in case the drill bit catches in the workpiece and the spindle rotates while the chuck flies free :shock:
Steve.
Steve.
