Good points.
Does the guide bush thing have anything to do with them usually mainly being used for worktop and similar jigs? I've a set of the various sizes (fits the Trend spacings, incl. the Unibase for my smaller routers) but don't use many of them.
The depth shaft is a standard 10mm thread, IIRC, so 1.5mm/rev. I bet you could fit a T11 one to a T10/625 with a bit of fiddling, but it's sort-of missing the other point - the advantage of a big, open base for cutter changing is huge. Now I've got a T11, I wouldn't want to go back to squeezing a cranked spanner in, etc. The rather nice single ended spanner that came with it almost always fits perfectly, from above the table.
I haven't had an occasion when I've needed to drop a large cutter below the top (apart from
this one, but even it is craftily shaped to be narrower at the bottom), but spannering from the top is dead handy. In theory I should just remove the router plate from the table and do the setup with the router+plate tipped over on the tabletop, but my router plate is shimmed along the back edge to give a precise distance to the table track. Spannering from above means I needn't disturb it.
Sorry - virtually a thread hijack! I hardly ever do worktops, so my 1/2" routers get far less use than when table mounted. Almost all handheld stuff is done by a couple of small Bosch ones. So the 625/T10 thing is moot (for me), as nobody makes a T11 clone as far as I know.
If it _is_ for worktops and stair jigs, etc, then a T10 ought to be as good as a 635/CMT.
Oddly, CPC also have a T5 on offer, for
more than the T10 - how does that work??? :shock:
E.
