Delta 785 Bandsaw
u15jmw
10 Feb 2013
Solihull
Just picked up this old bandsaw cheap, but it needs a new guide for the blade that sits in the table. Not sure if I've phrased that right, but the current aluminium guide is really chewed up!
I assume I'd need to get it made. Suggestions would be greatly appreciated.
Thanks. It's the small insert in the table. I'll try to get a pic tomorrow. If it can be made of anything, then I guess I'll just have a go and make something from a bit of plywood. You'll have to excuse my ignorance, just getting started with woodwork!
the original ones are probably plastic and do get damaged. I have an aluminium one in my bandsaw, made by the last owner as an upgrade.
Do you have a lathe- they are a few minutes work for a turner, but probably a whole lot more difficult without.
Also measure the hole- there is probably a replacement for another saw that will fit.
